Compatibility of different range extenders
Heddonite
Can anyone tell me if the BT range extender discs work with the square  EE  range extenders? Due to a long list of mishaps (see previous post) I had  “contracts” set up by both EE and BT. The square EE range extender works well but doesn’t cover the whole house. I also have a BT disc but when I tried to link it to the EE Smarthub and extender I couldn’t get it to work.
8 REPLIES 8
@Heddonite : No, they do not mix. The black BT Complete WiFi discs are intended to work only with the BT Smart Hub 2.
Community Hero
Community Hero
@Heddonite And also the EE flavoured EE Smarthub (2023) version as well for that round Complete smart Wi-Fi disc! Position of your Square EE Smart wireless extender sitting on the floor is not helping much either.
Perhaps I wasn’t clear - can I use both BT disc and EE range extenders together to extend broadband through the house?
Sent from my iPhone
@Heddonite Here is the link to the current EE Routers and smart wireless units. And depending ON what you have depends on what you can do!
https://ee.co.uk/help/broadband/getting-started/setting-up-smart-wifi
Let's be sure which EE extenders you're trying to mix with. What is the name of the EE BB plan are you on including its speed? Which EE router & WiFi extenders, if any, do you have (read label or post a pix)?
Thanks. Please see the photos in my original post.
Sent from my iPhone
There are few that look alike at that scale but have diff abilities. Please read the labels or post pix of them. The backs and bases are more informative.
@Heddonite Your photos are off no help to determine what you have, best you do the what is on the label printed for the units!
