Can you seperate the wifi bands and name on ee smart hub pro
TheWirralWhite
Having major connection issues with all my chromecasts since upgrading to Android 14, guaranteed google will say opt for just 5g bands,  if this possible seen conflicting info saying possible on some ee routers but not all?
12 REPLIES 12
Have 4 of the Google tv ones inc 1 4k just the 3 I sadly updated to Android 14 having issues
@bobpullen wrote:
Not sure you can turn off 2.4GHz on Compatible WiFi.
Yes, I was wrong originally. Compatible WiFi comes with the 2.4 GHz band ON & you can add the 5 GHz band to it or not.
I've only one Google TV Chromecast (it's the non-4k one). Seems to connect fine. Have you tried factory resetting it and starting from scratch? No idea if mine has upgraded to Android 14 but I'd assume it's up to date as I don't do anything to avoid it.
