Can't pair to hub
Emmvee
Hello
I cannot pair my Huawei p30 pro to my brand new  EE hub.
If I login to the hub via 192.168.1.254 but not sure what to do next.
Please could someone help on exactly what to do as I am not very technical
Thank you
Update:
I have found a fix for this, I can now pair my Huawei p30 pro to my hub.
Got to phone settings
Select Apps
Select EE app
Select Write System Settings
Turn on
Go back to home and start EE app and it should now pair with hub
27 REPLIES 27
Emmvee
Hi
I've just switched to ee and have the same issue as you did. Could you explain what you did to solve this.
I'm not technically minded but I have gotten into the hub via the IP address you gave, after that I'm a bit lost as what to do 🙈
@Emmvee : Login to your EE Smart Hub/Router at http://192.168.1.254 with the admin password on the bottom of the slider label on the back of the router. Then on the Advanced > Advanced Wireless page you should be able to see your WiFi SSID & password in clear & change them if you like.
Emmvee
 @XRaySpeX is this the correct screen ?
@Emmvee  : Not for what I asked of the OP. No screen was requested. I was asking for knowledge of BB plan & router, possibly with an image of it. See what the OP answered.
What exactly are you trying to achieve?
This is the danger of latching on to somebody else thread w/out stating what issue you are trying to overcome. Try starting your own thread & explain your issue.
Hi @XRaySpeX
I was replying to you message to me sent 03-03-2025 12:45 PM
Sorry for the confusion
Sorry, @Emmvee , I'm confused! Your last post WASn't a reply to my previous post of 03-03-2025 12:45 PM. It IS a reply to that post & doesn't add anything. Plus you are posting over 2 other OPs' threads.
& I still haven't the faintest idea what your issue is.
Apologies @XRaySpeX
I'm new so I may have pressed something wrong🙈
How can I continue this conversation without confusion
@Emmvee : Start your own thread & explain your issue & circumstances in detail & we'll do our best to help you with it.
@XRaySpeX
Thank you
I have done that.
