10-03-2025 01:32 PM
My neighbour is a CB radio enthusiast who claims he gets constant interference and poor signal on his radio devise when my internet is on which to be fair is nearly always except when I’m on holiday . He has taken advice from his groups and they say it’s my router which is causing the problem . He has asked me to call EE tech team to help before he reports it to Offcom . Any advice ?
11-03-2025 07:26 AM
IMHO let EE sort it out. Let your neighbour report EE to Offcom. It’s not a problem of your making.
11-03-2025 08:35 AM
Very hard to argue with any other poster suggesting you wash your hands of this issue.
You're legally using equipment that's approved for use. If anyone is reporting a wireless issue that they allege is caused by you, let them prove it via the appropriate channels - which means Ofcom.
Much depends whether you feel that assisting to a certain point will only fuel the issue, or may help resolve.
11-03-2025 09:27 AM
Thanks for that advice , I’m sure you’re right 👍
11-03-2025 09:29 AM
Trouble is we get on well and it’s his hobby so don’t want to appear unhelpful so might just call EE tech team to inform them about the issue then I’ll have done my bit
11-03-2025 10:18 AM
Yes, it's worth mentioning that you are absolutely right. I've been around the block a good few times and one thing that is extremely important throughout your life is to get on with your neighbours. It makes every day life infinitely better. Well done.
11-03-2025 10:21 AM
What do you propose, the neighbour moves his equipment further away or moves out completely?
Chances are his equipment is picking up EMI or DOCSIS is running on 27mhz which is the same frequency as CB radio
11-03-2025 11:23 AM
Thanks for your comment . I’ll maybe suggest that to him . I’ve had no luck speaking to EE tech ream - gave up after an hour trying - nightmare
04-06-2025 09:39 AM
I'm a little late to this topic and found it by accident while doing some research on a tenuously related topic.
All electronic equipment has the potential to cause radio interference, including various types of routers. As your neighbour is a CB user he has little in the way of any legal recourse. CB radio was deregulated in the 90's, meaning users were no longer required to purchase a license to use the service, and as a result were no longer considered a protected service. I doubt OFCOM will be interested in following up his complaint and will likely close the case without any investigation.
A common source of interference to the CB bands that is internet related is the emissions from HomePlug devices, the devices that some use to increase the range of their network by passing ethernet over the mains wiring. These are essentially radio transceivers operating on the Shortwave and VHF frequencies. Because house wiring is unshielded and unbalanced the energy from these devices is free to radiate, and can radiate quite a distance. All devices sold today have to be prevented from radiating in the primary amateur radio allocations and those used by essential services, CB radio is not classed as either and therefore no restrictions on emissions on those frequencies are in place. It's also worth noting that a very large amount of digital electronic equipment use oscillators running at 13.560MHz, the second harmonic of which is 27.120MHz, which is withing the CEPT CB allocation.
As others have stated the onus is not on you to fix the problem as you are using the equipment supplied by your ISP as intended. One thing your neighbour needs to do is determine by which method the interference is getting into his equipment. This means is it coming via his antenna? Is it being picked up by the shield of the coax he is using (known as common mode interference)? If it's coming via his antenna then repositioning his antenna may reduce the effect. If it's coming in via his coax shielding then a common mode filter or line isolator may reduce the interference. It could even be mains borne and therefore mains filters may help.
I do have sympathy with your neighbour but to make accusations from the start is not the way to go about things and often leads to unwanted tensions between neighbours. I'm a licensed radio amateur and I live in a typical suburban environment. Consequently I am surrounded by a multitude of unwanted sources of interference. These range from cheap phone chargers, battery chargers, inverters used in Solar installations, VDSL leakage from overhead telephone cables, switch mode power supplies used in set top boxes (Sky, Virgin Media, EE, etc), in fact anything electronic can cause unwanted interference. Rather than waste my time knocking on everyone's door insisting they turn everything off I have tried my best to adapt to the environment. This has included carefully choosing the type of antennas I use and their locations on my property. I have also built some heavy duty mains filtering to ensure there is no noise from other properties getting into my property.
Have all my preventative measures ensured that I'm free from locally generated radio interference? No, but it's a compromise. I have a license to do what I do and I'm fully entitled to do what I do. But by the same token my neighbours have bought their electronic gadgets in good faith and are using them as intended and are free to do so. If anyone is to blame it is the manufacturers for not applying the appropriate filtering, and the regulatory bodies for not enforcing their own requirements.
