EE BrightBox loss of internet when City Fibre installed nearby
eemh
Skilled Contributor
Skilled Contributor
Thank you  @XRaySpeX  for your related post.  I am technical support for my elderly blind mother-in-law living in bungalow just around the corner.  She only uses the internet for radio via Alexa.  Last week her internet stopped working.  Unplugging the BrightBox for a minute and replugging had no effect, nor did doing the same to Alexa.  Her landline is working as usual.
City Fibre have been at work in the village and she recently had a paper through her door, and an email, that it was now all ready for her to change over to one of their providers.  Her internet disconnected at the same time.  I rang City Fibre to ask if this was just a coincidence but they haven't got back to me.  I am disappointed if it has caused her problem as I had logged her as Vulnerable with EE after she went blind some years ago.
I did some research and today I logged into her Brightbox from my phone and looked at all the screens of information.  It all seemed to be working ok except for Internet - not connected.  I tapped on Connect, and it told me to wait a minute, but after several minutes nothing had changed.
I noticed there is a drop-down box about broadband - either ADSL or Fibre.  Should I try changing this from ADSL to Fibre and see what happens?  I didn't want to break anything or cut her off completely!
Thank you
Matthew
Edit: the internet light on the front is flashing.  I read that this means there is a message for me inside, but there wasn't.
eemh
Skilled Contributor
Skilled Contributor
Hi @Lesley_W  and @Peter_W
We finally got it solved yesterday evening, so I think this is the post that should be marked as Solution.
My previous experiences of calling the EE helpline had been of long waits, so I had been trying to solve the problem myself after we returned from holiday to find Mum's internet broken.  Hence my post here.
I had rung up City Fibre and had an email from them several days later saying there had been a 'cable strike' and to contact EE.
I rang EE on Friday 28/11 and spoke to a gentleman who ran tests and ordered a new router to replace her 'antique' EE BrightBox and booked an engineer who attended later on Friday.  He told Mum that the cable strike could have broken her EE Brightbox which he unplugged.  The gentleman I spoke to that morning had already ordered a new router.
The new router was dispatched on Friday by Royal Mail Track 24, and arrived on Tuesday.  I plugged it in and after it had set itself up there was still no internet and it told me to ring EE helpline.
A very helpful lady (I will commend her to you by name in a PM) organised some long and complex tests and discovered:
  • there may have been a 'card failure' at the exchange
  • and there was a software failure somewhere
So she got BT Openworld onto it and called me back in the evening, when they said it had been fixed, so I went over to Mum's and the aqua internet light was on.  I got her ancient tablet (pre-blindness) connected and then Alexa so she has radio again.  She also has been compensated for lost connection time.  Thank you to all involved.
20 REPLIES 20
Peter_W
Welcome back to the Community, @eemh.
I'd like to make sure we get this checked out right away, so I've just popped you over a private message.
Peter
Maestro
Maestro
@eemh EE only use OR for connection, so the EE Brightbox is not going to work on another ISP's Fibre connection! May also just be something that CF disturbed when connecting up another customer, may be a chance they are using the OR PIA to get there Fibre about!
Sounds like CityFibre (CF) has interfered with your line or even taken it over. You should check with both EE & CF that your line hasn't been taken over by CF. Even if it had your line should still work as CF don't supply BB down a copper landline that you have but over a separate fibre line. Otherwise report a fault to EE.
You could try switching the router to Fibre but it probably won't work as the Full Fibre supplied by CF is not that type of Fibre. Better still on the Advanced > Broadband Settings page tick the box for "Enable ADSL/Fibre auto sensing" & it'll work it out for itself.
The Internet light flashing Green should mean you have a complete connection & there is traffic down it. Is it Green? What colour & state is the Broadband light above it.
@JimM11 : The EE Brightbox will work on any Fibre, Full or partial, connection up to 1 Gig. Just like any generic router! I'm doing so. Of course to have CF's Full Fibre an ONT would have to be installed inside the premises & there's no mention of that or any work being done to the home.
@XRaySpeX That's a handy to know, the bright box can be adjusted for all wan connection types and account's password's and if needed vlan's. Pretty decent EE Router then!
eemh
Skilled Contributor
Skilled Contributor
the light flashing on internet is white
eemh
Skilled Contributor
Skilled Contributor
no work has been done inside the bungalow
@eemh Have no idea on a Brightbox, @XRaySpeX is the one for that unit!
I don't see flashing White. What's Broadband light doing?
