Broadband
Ibartdeco51
Broadband sluggish especially between 4-8pm I’m on MPB tariff.
What is the name of the EE BB plan are you on including its speed? Which EE router & WiFi extenders, if any, do you have (read label or post a pix)?
Hi Xspecs
I’m on the following:
Full Fibre 150
149 mbps
Smart Hub SH40J
Regards
Les
Sent from my iPhone
  • For a SmartHub: login and go to Advanced Settings > Technical Log > Information. Obscure your names & any numbers in the BB Username & also the SSIDs. Also post the Home > Status page.
2. Try a speedtest, preferably wired using an Ethernet cable supplied with the router, here http://www.thinkbroadband.com/speedtest.html . Click on the "Results Page" button at the bottom of the graph you first see and then copy to here just the "Link to this result:" link that you see below the next main graph.
Do the above both during the sluggish period & outside it.
