Broadband
Pb-49
My internet seems to be down more often. Then it’s up. I can’t do anything an d always have to wait for it to come back up, I am really fed up with it now. What are you goin B to do about it
Mustrum
@Pb-49   this is not customer services. so there is only a limited amount of things people on here can suggest.
Have you reported a fault to Customer services?
What type of broadband package do you have?
Do you notice what lights are showing on the router when you have problems?
