Broadband
It123
I've upgraded my broadband to fibre, received a new router without any additional information. I don't know if I need an engineers visit, if I should plug it in as I don't know if my new service is activated, my std broadband is working, any advice is appreciated.
Mustrum
What broadband package did you upgrade to? Which router do you have now, and which one have they given you?
If you post the results after entering your phone number into this checker we may be able to work it out.
https://www.broadbandchecker.btwholesale.com/#/ADSL
@It123   You should of got an email ( also check your spam folder )  about your go live date for your new BB package.
As you upgraded your BB the new router will work both on the old & the new.
To check which BB you are currently on, post your full router stats from either router:
You should've been told of your "go live" date. Has it come to pass?
