Broadband speed
1699226
When I`m taking a look at my Plan details , I`m not sure I can see the speed this plan should provide. Is there a way to figure it out? Because in fact my speed check is showing  smth like this and I`d like to compare it to the plan:Screenshot_1.jpg
Which EE BB plan are you on?
In your MyEE for BB : BROADBAND > Your broadband speed
I am on BB plan "Fibre PlusBroadband without landline", pls see attached.Screenshot_3.jpg
