Broadband speed so bad in evening
Michelle193
I went from Bt to EE as they said bt only buisness from june with digital voice phone which is no good when speed drops.I have had 4 outreach engineers out and stephen from liverpool as EE said ive been forward to techs high complaint no phone calls no compensation as promised made me so ill.My broadband drops as soon as everyone comes home  from school work  in other houses then games it goes to 2mpb from anytime from 7.30pm to 11pm. I dont even have gaming and my guaranteed speed is 23 lol . its a joke noone has rang me??? And carnt get through on busy EE with all the complaints
8 REPLIES 8
Brilliant Contributor
@Michelle193 There is no one on the public forum that has any access or account information regarding your issue, you can only pursue it through calling EE CS, have you run the text test to your line from your mobile. The details are below they test your line, and will call you back if an issue is found. Text the help below.
Text EE for a call back
If you need help with your broadband, text HELP to 66033
If you need help with your landline, text PHONE to 66033
Charges may apply at your standard rate.
  1. We’ll run tests on your connection to find out what’s going on.
  2. If you need an engineer, we’ll text you in 15 minutes to book a slot.
  3. If you don’t need an engineer, we’ll call you within 30 minutes to help solve your issue.
Opening hours:
Monday to Friday, 8am to 9pm
Saturday and Sunday, 8am to 8pm
Call us
From your EE mobile
150
From any other phone
0330 123 1105
Calls are free from an EE number. Charges may apply if you call from another network.
Michelle193
This was already done its been on going complaint waiting for them to contact me from the tech complaints i have a open complaint.Its ok in the day!!!They knows this
@Michelle193 If you have a complaint reference, you should be able to track what's going on regarding it possibly from your EE account. Getting through to speak to someone does appear to be difficult.
Which EE BB plan are you on? What EE router do you have?
Why does it matter plan router its fine in the day and its only happened since EE .im on fibre essentials 36  smart hub plus .It was fine for couple months
So I might be able to help you with your slow BB speed issues with certain of EE's BB plans. Yours is 1 of them.
I carnt do all that
Sent from my Galaxy
OK!
