on 19-06-2023 09:10 PM
Can anybody tell why my router cycles (reboots) everyday at the same time (9pm)? Are these planned outages?
on 19-06-2023 09:41 PM
@Kriesch Very unlikely to be planned outages, more likely to be some kind of local interference.
Does anything happen at that time, do you have any timer switching something one then, could it be street lights, or maybe local business turning lights on?
In the mean time, which router do you have?
Are you able to log into it and share the WAN activity log? We can help more if we know which router.
Hope this helps get you thinking about something that may help us narrow things down.
on 19-06-2023 10:02 PM
Hi Mustrum,
Thanks for your response.
We did think that it may be linked to a local event, but there isn’t anything obvious that happens at that time.
The router is an EE Smart Hub.
How do I check WAN log?
Thanks, Kriesch
19-06-2023 10:15 PM - edited 19-06-2023 11:07 PM
Do you really mean it reboots itself (v. unlikely) or just that it keeps reconnecting? What colours are the light sequence when this happens?
Post your full router stats:
on 19-06-2023 11:00 PM
Hi XRaySpex,
thanks for your reply.
It’s not a cold reboot, it appears to be a warm reboot, like it starts the connection cycle.
The sequence includes flashing yellow, then flashing blue then constant blue when reconnected.
I’ll get the data asap.
on 19-06-2023 11:09 PM
That's a re-sync, not a reboot. Just the line going down for some reason.
Locate the hidden test socket that is revealed when you remove the bottom half of the split faceplate (2 screws or press tabs) of your master socket. Only do this if you have a split faceplate. Do you have any extension sockets in the home even if unused? Are there any wires connected to back of faceplate of master socket?
Try the BT Quiet Line Test (QLT), dial 17070 Opt 2, preferably with a corded phone, in the test socket with the router disconnected. If there is any noise, report it to your landline provider as a voice fault (don't mention Broadband). Often sorting out voice faults will fix the Broadband as well.
Reboot the router & plug it into the test socket. Post the full router stats & System Uptime when plugged into test socket.
Is the issue any better?
on 23-09-2024 06:28 PM
Mine does the same everyday, what I have noticed is that the time is the same as some of the scheduled groups time of internet connection to be off
on 23-09-2024 08:01 PM
@Romkin Is there anything showing in your event advanced log?
on 24-09-2024 12:03 AM
Nothing unusual, only that devices been reconnected
24-09-2024 07:34 AM - edited 24-09-2024 07:40 AM
@Romkin What router do you have? If the latest EE Smarthub+, then 1st screen Status will have values something along these lines, if you are having reset's then network uptime will be the one that will show! How does yours look. If you think that parental controls are causing, if you look at the screen after your block then see if the value is changed.
Downstream sync speed: 47.38 Mbps
