on 19-11-2024 03:00 PM
Hi just lost broadband connectivity
Solved! Go to Solution.
on 19-11-2024 03:14 PM
on 19-11-2024 03:03 PM
@JohanL If you wish go to the help link and find what you need, can check if you have an area wide fault or if EE even know about anything as yet.
@JohanL Follow the steps here https://ee.co.uk/help/contact-ee/technical-support/broadband-landline
