29-09-2022 11:07 PM
All I want to do is watch Drag Race on iplayer, sigh
29-09-2022 11:09 PM
29-09-2022 11:12 PM
And still my broadband is dropping out. I had WiFi a week ago, in the middle of the Norwegian Sea, on a boat, so why is it so difficult to get it 5 miles away from a major city?
30-09-2022 12:37 PM
If you post the information requested by @XRaySpeX you will get an answer and probable solution.
