Broadband drop out
Casper1973
5 days in from switching to EE Broadband from BT. All set up correctly but, having to continuously resign in on Smart TVs, Firestock & Android phones due to Internet dropping ? If ever BT dropped out never had to sign in continuously ! Connection very intermittent and becoming frustrated ! Yes it says allow 10 days for speed to settle down but this isnt due to speed, thats fine when working. Habe spoke to 3 different people at EE so far,they cant detect any faults ?? Help ??
Jon_K
Former EE Employee
Hi @Casper1973.
Welcome to the community.
Do the lights change on the router when the dropouts happen?
One of our community broadband experts may be able to help you with the performance of your broadband based on your stats.
Jon
Hi, sometimes they change sometimes they don't,very intermittent  !
Haven't had any kind of constant connection since we went live. Have an engineer coming tomorrow!
Mustrum
The 10 day thing is a hangover from adsl days, not applicable to fibre.
Is it just wifi that is dropping, or is the router rebooting?
Are you able to log into the router to view the logs? They can be filtered to help look for patterns.
If that fails or you can't do it, have you tried the BT router again?
