on 08-11-2024 08:48 PM
I have just joined EE and received the new so called smart hub, the set up was easy, however the coverage in my house is terrible and it only provides signal in two rooms, the speed is lower than the promised speed - promised 29mps receive 20 and that is after a week, that's bad enough but I could probably live with that if it was all over the house, I have tried to call them on 150 but I can never get through to speak to anyone, got close today but they said it was going to be 45min, then they decided to test the line and dropped out my call, I cannot find a direct phone number for them, it's ironic as they say if they cannot provide the speed or coverage you can cancel your contract without a fee, how can you when there is no one to speak to, any help with a direct phone number would be great
on 08-11-2024 09:33 PM
@Frax Just click on the link below, and go where you need and numbers will be shown.
08-11-2024 09:53 PM - edited 08-11-2024 09:54 PM
Did EE give you 1 or more Smart WiFi Plus extenders with your router to extend coverage within your home?
Try calling CS on the Freephone no. (Opt. 2) in my sig.
on 08-11-2024 10:01 PM
Hi and thank you for the reply, no all I got was the smart hub and no extenders
on 08-11-2024 10:02 PM
Thank you
08-11-2024 10:07 PM - edited 08-11-2024 10:08 PM
Which EE router have you? Smart Hub Plus or Pro?
You can get up to 3 WiFi extenders from EE. Phone CS & ask for them.
on 08-11-2024 10:07 PM
@Frax From who did you come from ISP to EE and did you have the router supplied by that provider, you obviously have and accepted that you speed was low, so unless you have a fault that was carried over you can text HELP to 66033. EE will run a diagnostic test and take it from there. It's all detailed in the link above.
on 08-11-2024 10:12 PM
I think it's this one Smart Hub Plus Sh31b Wifi 6 Router, well it looks like this one
on 08-11-2024 10:14 PM
I have had a house move, my last router was a EE WI/FI router which worked well but next to no signal at this house
Which EE BB plan are you on including its speed?
