Broadband buffering
Spitfire1
I have fibreplus but still get download buffer.  70mb is coming into the router but seems to be lost getting to the smart sky TV.
2. Try both a wired & a wireless speedtest here http://www.thinkbroadband.com/speedtest.html . Click on the "Results Page" button at the bottom of the graph you first see and then copy to here just the "Link to this result:" link that you see below the next main graph.
crunchy
some basic trouble shooting that could solve your issues without going through all the tests above.
are you connected via wifi or cable to your tv ?
if its wifi, does your tv support 2.4ghz or 5ghz wifi ?
if its 2.4ghz and a slower protocol like 802.11b (max 11mbps) that will reduce your possible maximum download speed significantly, connecting to your router with a network cable will be faster.
