BT AVAILABILITY CHECKER SAYS FTTP AVAILABLE, WHAT DOES IT MEAN?
Justachillguy
Hello everyone!
I was just wondering if anyone can explain what this means? Have the building works been completed and they just need to install the box in my flat? Or the whole process needs to be done? Been waiting for quite a while now and I just don`t understand.. Captură de ecran 2025-03-29 183456.png
Mustrum
@Justachillguy   It says that you can order FTTP, however there is still external work to be done.
Once an order is placed Openreach will need to survey and work out how they will get the fibre to your flat. Until that and the external build is done you will not know how long it will be to complete.
Openreach may also need to get agreement from the landlord, depending on how the final solution is worked out.
HTH
