Broadband speed
kim51lee63
HI, since moving over to EE, my internet speed has dropped and on one occasion failed altogether. One new hub and a visit by an engineer, no better. Call after call and all you get is "well, you are getting the minimum guaranteed speed so what's the problem ?". The problem is that it is so slow work is difficult at best, just no help at all, am I the only one with this issue ?.I never had this with BT, should have stayed with them.
11 REPLIES 11
@kim51lee63 : What is the name of the EE BB plan are you on including its speed? What EE router & WiFi extenders do you have (read label or post a pix)?
kim51lee63
Hi, BB is Essentials 67, router is a Smart Hub Plus. Last readings, download @ 59.9 mbs, upload @ 13.8 mbs, compared too expected range of 66 to 76 and 17 to 19 respectively. When I was with BT, speeds varied between 70 to 75, in other words usable. The main issue here is that BT offered a better service all round, problems were rare but remedied quickly, EE just don't seem to have the same commitment.
  • For a SmartHub: login and go to Advanced Settings > Technical Log > Information. Obscure your names & any numbers in the BB Username & also the SSIDs. Also post the Home > Status page.
2. Try a speedtest, preferably wired using an Ethernet cable supplied with the router, here http://www.thinkbroadband.com/speedtest.html . Click on the "Results Page" button at the bottom of the graph you first see and then copy to here just the "Link to this result:" link that you see below the next main graph.
Hi, no more, this is something EE should be doing. I will be opting out of EE at the earliest, unfortunately, my contract is till April next year,  thank you anyway.
Well, you came here for help!
Peter_W
Hi @kim51lee63.
Welcome to the Community!
Whilst we don't have account access via these forums, there are sometimes troubleshooting steps we can try to help resolve your issue.
This does require you to check a few things though like @XRaySpeX has recommended.
If you'd prefer for us to run some checks directly, you can send us a text with HELP to 66033 and we'll guide you through some steps, test your line and if needs be get you a call back from our team.
Peter
Matt_124
Hi @Peter_W
Is the number not 66033 or has this been changed?
Mustrum
It is.
Contact us about your broadband and landline
Text EE for a call back
If you need help with your broadband, text HELP to 66033
If you need help with your landline, text PHONE to 66033
Charges may apply at your standard rate.
  1. We’ll run tests on your connection to find out what’s going on.
  2. If you need an engineer, we’ll text you in 15 minutes to book a slot.
  3. If you don’t need an engineer, we’ll call you within 30 minutes to help solve your issue.
Opening hours:
Monday to Friday, 8am to 9pm
Saturday and Sunday, 8am to 8pm
Call us
From your EE mobile
150
From any other phone
0330 123 1105
Calls are free from an EE number. Charges may apply if you call from another network.
Peter_W
@Matt_124 it is indeed... I'll edit my post, must have been a momentary blip 😅
Peter
