28-02-2025 05:53 PM
Recently switched from BT Broadband to EE and the broadband connection isn't particularly stable. It drops, typically for a couple of minutes, 2 or 3 times a day. The set up is more complicated than with the former BT Hub (v6) as it's added the Smart Hybrid Connect box and a Smart WiFi Plus box to a network with several Devlolo powerline adapters. In addition to the internet connection dropping, the Hybrid Connect box also seems to randomly lose connection with the hub. Half the time the EE App shows "there is a problem" when trying to manage broadband and I'm losing count of the number of times I've deleted and re-installed the app om both my iPhone and my iPad. For the most part, the TV Box Pro and Mini TV Box are behaving themselves (apart from when the internet connection is lost). Is there a compatibility issue somewhere, perhaps with the powerline adapters?
28-02-2025 06:06 PM
Which EE BB plan are you on including its speed?
28-02-2025 07:02 PM
28-02-2025 07:16 PM
2. Try a speedtest, preferably wired using an Ethernet cable supplied with the router, here http://www.thinkbroadband.com/speedtest.html . Click on the "Results Page" button at the bottom of the graph you first see and then copy to here just the "Link to this result:" link that you see below the next main graph.
01-03-2025 07:34 AM
01-03-2025 10:24 AM
The 2 links apart from the TBB speedtest are meaningless here.
Use the Camera icon above your text to upload an image file to here.
01-03-2025 10:32 AM
01-03-2025 10:43 AM
Your BB speeds are fine. You are getting the full 50 Meg down from it.
Locate the hidden test socket that is revealed when you remove the bottom half of the split faceplate (2 screws or press tabs) of your master socket. Only do this if you have a split faceplate. Do you have any extension sockets in the home even if unused? Are there any wires connected to back of faceplate of master socket?
Only if you have an active landline, try the BT Quiet Line Test (QLT), dial 17070 Opt 2, preferably with a corded phone, in the test socket with the router disconnected. If there is any noise, report it to your landline provider as a voice fault (don't mention Broadband). Often sorting out voice faults will fix the Broadband as well.
Reboot the router & plug it into the test socket using a DSL dangly micro-filter. Post the full router stats & System Uptime when plugged into test socket.
Is the issue any better?
