TPLink direct replacement for EE superhub plus?
AndyC-66
Is there a TPlink modem router that could directly replace the EE superhub plus?
I’ve seen the Archer VR2100 which is compatible with my powerline adaptors, and Onemesh.
Any tips or tricks?
thanks.
Mustrum
@AndyC-66   Then you just need to use the info on the following help -age to set up the router.
https://ee.co.uk/help/broadband/getting-started/using-and-configuring-a-third-party-router
Maestro
Maestro
@AndyC-66 If you have a fttc OR Master socket for connection, do not require to use a digital voice or have the landline connected to such then the Tp-Link should connect fine, as to the One Mesh capable that you need to check and also anything else to merge with it in the Tp-Link line!
I have. BT master socket with 2 sockets.
i don’t have any landline phones in the house any more.
@AndyC-66 Powerline did work fine av600 lan and wireless modules on the EE Smarthub+ also just so you are aware!
The Archer VX1800v would be closer in operation to the EE Plus operation if it does match with your other One Mesh!
Thanks. Seems according to the TPlink  the Archer vx1800v is end of life and being replaced by another model. Which is good as I will be able to get one cheaper! Hopefully.
Mustrum
