All our brilliant teams are based in the UK or Ireland.
Calling from EE mobile 150
Free to pay monthly
25p per call on pay as you go
Calling from a landline or another provider
0330 123 1105
08-08-2023 01:20 PM
IPSWICH IP3 - Had several outages in the last 24hrs. Some sessions lasting no more than 10 mins, the odd one 45 mins. Windows network reset, router reset, checked for viruses, even went VPN for a while to see if my IP was beeing targeted. Any known problems in this location?
11-08-2023 10:38 PM - edited 11-08-2023 10:43 PM
Last 24hrs. Rock solid connection. I'm guessing it might have been related to my line not coping with data throughput. The router was showing around 50Mbps download sync speed & all the subsequent outages. Now it's been reduced to 42Mbps & a slightly lowered upload sync.
08-08-2023 01:52 PM
@chrisd0407 are you on full fibre or still on a phone line?
If the latter, is your phone working OK and is the line quiet? Dial 17070 option 2.
Do the lights o the router change when you have these outages?
Have you reported a fault to the Broadband Care Team?
Free to pay monthly
0330 123 1105
08-08-2023 02:04 PM
Hi Mustrum
Am fibre via phone line. Landline okay and the line quiet. No lights on the router other than the one large one on the front which, no surprise, turns red. At the moment this my only report. The network status reports no problems in my area, but then when you continue to report one, you can't get passed its insistance on entering an EE mobile number. Not a service I have. That is something else that needs looking at for customers.
08-08-2023 02:06 PM
@chrisd0407 that checker is for the mobile network, not landline/broadband.
08-08-2023 02:12 PM
If there's another link where I can continue to report it, please. provide.
08-08-2023 02:15 PM
@chrisd0407 there is no link, just use the numbers and speak to them.
08-08-2023 02:39 PM
If it is a neighbourhood issue, you could consult BT Service Status to see if any faults are being attended to in your local area.
08-08-2023 04:46 PM
Thanks to both for your help. So anyone else reading this thread can learn from the process am posting here. The BT Service link is useful as you TEXT it and it automatically runs test, in my case transfered to an EE text number. If you still need service after it does its checks, a text of GUIDE back initiates a call back to your mobile from EE to start analysis. They called me back very quickly & sounded very knowlegable. Sent off two packets of data, one to the modem, and one to my cabinet (didn't know they could do that) & perhaps crucially identified one area of the possible problem was my immediate surroundings was a bit data congested, so put me on another channel. We are giving it 24-hours (it has gone down again while writing this) and provided his personal email so we can pick up tommorrow if need be. Fingers crossed.
08-08-2023 06:20 PM
** The basic line test then gives a TEXT number to follow up I should have said.
09-08-2023 07:50 AM
Good morning.
Is your broadband back up and running? As I woke this morning to find my broadband has gone down without warning.
