close
netgear night hawk mr1100 not connect to ee
syd11
Northerner
Hi @syd11
What SIM are you using, pay monthly account or PAYG?
Are you in the UK?
13 REPLIES 13
@syd11   Have you set it up correctly to use EE ?
Northerner
Hi @syd11
Are you in the UK?
I think so I was trying to use a payg sim from ee
And yes in the uk
EssexBoyEE
What's the history on the Router or where did it come from, there are various Models / Firmware on these.
What's the full Model Number
 ending with, should be on the Box.
Telstra works fine on three but no other sim car will work
Does any one no what the settings should be for nighthawk netgear mr1100 for EE
as on the app there is not much choice .
syd11
Looks like I’m stuck with three data sim
good job I did not go into contact with EE as the nighthawk netgear mr1100 does not work on there network
and there customer service is more than useless.
So its from the Telstra Network ?
