close
mini wifi mobile hotspot
JPS55
hello , how do I change the password for my mini mobile wifi hotspot device ?
Login to your MBB router at http://192.168.1.1 with username/pwd as "admin"/"admin" or with the password found under the battery cover. Then on the WiFi Settings tab you should be able to see your WiFi password in clear & change it if you like.
