close
iPhone 6s can’t connect to any wifi network
Zorica
My iPhone 6s, can’t connect to any wifi network. I’ve done network reset.
@Zorica  If it doesn’t connect to any WiFi network it sound like the WiFi antenna is broken,  you’ll  have to contact Apple about this to get it fixed and if the device is over 12 months old and you don’t have Apple care it’s going to cost £ 282.44 as an out of warranty repair.
Although it discovers all networks around,
@Zorica   If it can see the networks then it should connect when you enter the correct passcode.
