close
data
ijx
Hi, today my data isn't working, it says i have no service ANYWHERE and every time i try use it in the car or out it doesn't work. i checked to see if i had none left but i have over 6GB left to use. i also reset network settings turned it off multiple times/ airplane mode switched but nothing is working what should i do???
11 REPLIES 11
@ijx   By the sounds of it yes you do.  You can request a replacement SIM card in a EE store or by calling customer services.  You must request for a replacement SIM card
Thanks for the help! am going to an ee store tmrw 🙂
-immy
