close
WiFi is intermittent. Openreach vans everywhere.
Shelly1802
WiFi is intermittent. Openreach vans everywhere. Anyone else having problems/know how long this will go on for? I work from home and rely on WiFi to do so!
[mod edit: Please do not post personal information on the public board. Thanks!]
@Shelly1802 : Welcome to EE's Home Broadband Forum.
OR are not touching your WiFi. That's entirely within your home & your concern. They might, however, be affecting your BB.
  • For a BrightBox: login and go to Advanced Settings/ System/ DSL Status. Also post 'System Uptime' from top of System Log page.
  • For a SmartHub: login and go to Advanced Settings/ Technical Log/ Information. Obscure your names & any numbers in the BB Username & also the SSIDs.
