close
WiFi Security on EE 4G router
PastaRasta
My Apple devices have started warning me that WPA/WPA2 (TKIP) is not considered secure and that I should configure the router to use WPA2 (AES) or WPA3. How do I do this?
@PastaRasta   Your iPhone s now only reporting this because you updated to iOS 14.
You was using that same security when you was using iOS 13.
Login to your MBB router at http://192.168.1.1 with username/pwd as "admin"/"admin" or with the password found under the battery cover. Then on the WiFi Settings tab you should be able to set:
It was advisory for you to have already been using these even on iOS 13.
