Community Activity
Izabela
I need history call form 28 may in coming and out
Openreach failed to install
After waiting a month for my install, the engineer came and said it would need a site visit, ground works and then a further install. He suggested at least another three weeks. I took a day off work for this appointment and my current supplier contra...
EE TV remote can’t select input sources
Just got a new Hisense TV and plugged in a new EE TV Box Pro for the first time. EE remote control paired with the TV perfectly and can control TV volume just fine. But when I try to select another input source, the source button on the EE remote ope...
Why is EE so rubbish
Seriously, have had a brand new S25 Ultra for 5 months and it has not worked properly since day 1. EE blame Samsung and Samsung blame them. Niether company will do anything to rectify it. Now the phone has decided to not connect to the network. I gue...
Resolved! EE App won't link products
I switched from BT to EE back in March - not only did it nearly take a month to reconnect the landline and new broadband, but I am now left paying for paper bills whilst I cannot get the EE app to recognise my account and link the landline and board ...
recently moved from plusnet to ee.now no cctv via ee 4G
Recently changed from plusnet mobile to EE .Since change unable to connect to smartwares cctv via EE 4G but fine via wifi.Cameras connect via another network 4G fine.Checked numerous times including areas with strong 4G signal and good speed checkAn...
no service
my phone hasnt had service for over 12hours i need help as i need my phone for work
Non Apple devices now do not save router password and often impossible to reset
Devices all worked fine on BT! WiFi is impossible since EE devices provided. What do you suggest. Also mobile router often red. Failure message indicates a weak signal on one. Have updated the password several times on devises none of which save afte...
