Weak Security
millomite
Since my ipad/iphone updated to iOs 14 I have a "weak Security" message underneath my WiFi router which is an EE Smart Hub. I need to change the encryption type to AES but there is no option on the Smart Hub to do that as far as I can see? Does anyone know how to do this or is the Smart Hub just out of date with its encryption type for security mode WAP2?
11 REPLIES 11
A quick Google shows that there is a security mode WPA2 (TKIP) which is weaker than WPA2 (AES). My observation that my EE router does not show which is being used is therefore valid and I will continue to try and get an answer from EE regarding this.
Very helpful to happily ignore on my settings.Just got connected to EE broadband with their brightbox router. I can fully believe that this is Apple getting uppity
