close
Voice activation
Raffaello2017
Skilled Contributor
Skilled Contributor
I’ve packed up an iPad Pro 12.9 to return under the 14 day EE return policies, but the voice  over has activated after I’ve reset to factory settings and removed from my iCloud. How can I stop the stupid thing telling me which way it’s being held, and what is happening every time I move it  ?
@Raffaello2017  Just turn it off then.
8 REPLIES 8
@Raffaello2017  Have you factory reset it ?   If not just to do that.  Setting>General>Erase all content and settings.  If it’s on iOS 15
If it’s on iOS 14 it’s Settings>General>Reset>Erase all content and settings.
@Chris_B Hi, yes I removed everything and reset it to the factory settings, so now the screen is white with, bonjour, hola, hello and all the other languages that appear before setting up.
@Chris_B @Addendum to last response, I have it packed up ready to return when it suddenly started talking.
@Chris_B Turn it off, like press up and down volume then the right hand side button ?
@Chris_B Hi Chris B, well okay so it’s now officially confirmed I am dumb, having unpacked the iPad I was able to turn it off thus terminating the voice activation. She no longer keeps telling me every mouvement I make. So the gold star 🌟 goes to you @Chris_B , for solving issue easily and effectively with simple solution.
@Raffaello2017  you packed it up switched on ???
 I’m trying not to laugh.  😆
@Chris_B Yeah ok Grand Master, it was packed up still on. I did say I’m officially dumb and I’m not even blond, so dumness comes in all shapes sizes and hair colours lol😂
