close
V Poor phone signal and no phone line for broadband at my static caravan.
Tarannau77
I have a static caravan located in a valley in Cornwall and I am struggling to get a reliable and stable Internet connection. A local company have installed a repeater on the side of my static caravan that picks up the signal from a local tower they manage with a BT fibre connection which is supposed to be capped at 20 Mbps. I would be very happy if I was getting that service but every evening the signal drops to practically nothing and I'm lucky to get 1 Mbps. I am looking for a Internet solution where I can stream Netflix and other TV services as well as using the Internet for Wi-Fi calling as there is no phone signal. I am not playing games online so would not describe myself as a heavy user.
My contract with EE comes with unlimited data and I have used the mobile hotspot on my phone to provide access to the Internet for my other devices when I have been travelling. Would it be possible to install something that will pick up an EE phone signal so I can use my hotspot on my phone as my Internet connection, providing Wi-Fi for my other devices? Or is there a more elegant solution available. I really am at my wits end. All suggestions are more than welcome.
Thank you in advance....
Nick
6 REPLIES 6
Christopher_G
Hi @Tarannau77
Does your phone internet work OK in your static caravan? From your last paragraph, I suspect not. We do sell a 4GEE WiFi router with an external antenna. However, that's designed really for areas where you get a good outdoor coverage but struggle with indoor coverage.
Do you get a signal when you stand outside of the bulding?
mikeliuk
Hi @Tarannau77 ,
In addition to the above checks, how does your location look on cellmapper.net for this and other service providers?
If the entire locality is red, it may set a more realistic expectation for what can be accomplished.
The above query regarding the outdoor signal is also useful.
@mikeliuk wrote:
Hi @Tarannau77 ,
For a straightforward comparison of alternate providers, I would recommend the Ofcom checker first & foremost. CM is good for many things, but it's not user-friendly for a simple coverage check.
Edited to add: The OP has mentioned in their first post about not considering themselves a heavy user, but also that they want to use streaming services. Live streaming video that could potentially be HD-standard, could easily qualify as being a heavy user!
What do you mean by having a BT Fibre connection thro' a repeater from a mobile mast? The 2 things are a contradiction in terms. Besides you say you have no landline.
Hi Chris would it be possible to have more information on the mobile broadband with Antenna please that sounds exactly what I need
regards
sandra
James_B
EE Community Manager
Hi @Sandylang63,
Please see shop.ee.co.uk/broadband/4g-home-broadband for more information.
Hope this helps.
