15-06-2021 11:52 AM
Hi All
Has anyone been able to stream their xbox away from home using 4gee wifi. I used to be able to do this with my fibre broadband before moving house and having to take the 4gee option. I think the issue may be something to do with it being a "mobile" network and not having a static IP address. Is it possible to assign a static so that this can be done? I don't use it often but would be good to be able to when away from home. Thanks
15-06-2021 01:42 PM
@T100mbo You can not have a static IP address when using cellular. Have you removed content lock for your EE4G WiFi account?
15-06-2021 06:44 PM
Neither on the EE fixed BB network nor the EE mobile network do you get a static public IP. So it can't be that!
You may be finding yourself up against a limitation of EE's mobile network. The EE mobile network uses Carrier Grade NAT (CGNAT) resulting in a double NAT, which means that you don't get your own public IP address but share it with other users. So you can't be uniquely id'ed on the Net & therefore your LAN cannot be addressed from outside for unsolicited accesses. This is unlike fixed BB.
If this occurs there is nowt you can do to avoid it.
16-06-2021 10:24 AM
16-06-2021 12:12 PM
Thanks! You're welcome 🙂 ! Glad I could be of assistance
