close
Using a 4G Router with a 1TB in use
Lancslawyer2501
Hi, I wondered if anyone knows if you can use your 4 g router in Spain: as in unplug at home then go away for three weeks (when we can!) and use the same router whilst abroad on the same plan with no messing about. I have a 1TB plan in place.
Any ideas? Especially with any potential agg with Brexit...
Northerner
Hi @Lancslawyer2501
As long as roaming is activated on your SIM, then it should work correctly. I would remind you to consider the roaming terms and conditions applicable to your plan which can be viewed here:
https://ee.co.uk/help/help-new/terms-and-conditions
EE Brexit roaming statement is here:
https://ee.co.uk/help/help-new/roaming-and-international/using-your-device-abroad/what-impact-will-b...
You may use that router roaming in the EU but will not have 1TB available. You will then have a 50GB data allowance and can't roam for more than 3 consecutive months.
bootjohn52
Yes can do. contact me via cheapdata dot nl
