23-09-2021 03:25 PM
I have just bought an OPPO A53 and I am finding it impossible to transfer image files to any of the following: Apple iMac, Apple MacBook Pro, or Dell Inspiron (Windows 10) lap top. I prefer to use the iMac where all my photos are stored.
When I plug the USB in Android File Transfer app starts up (as it should) but comes up with the error message "No Android found. Connect with USB cable". The Windows machine just ignores it! I have checked in the phone settings that USB capability is switched on and that I am using a cable which is good for charging AND data.
So what is preventing this transfer?
23-09-2021 05:06 PM
Hi @gez-jam.
Welcome to the community.
I know it's a long shot, but have you got another cable you can try?
Has this worked on a previous Android phone?
Jon
23-09-2021 08:48 PM
24-09-2021 08:28 AM
Thanks @gez-jam.
I've found this OPPO Help Page online which gives instructions on how to connect to an iMac.
Let me know if this helps.
Jon
24-09-2021 06:33 PM
25-09-2021 08:44 AM
Hi @gez-jam
Thanks for coming back to us.
It may be worth getting in touch with Oppo to see if they can suggest anything else for you to try.
Leanne,
