The output speed of EE routers?
davidscowan
Does EE reduce the output speed of its routers?  According to Open Reach, broadband arrives at the router at 17mp/s but the router "Downstream sync speed" is about 20% less. And I am getting less still when I measure the speed.  Could it be that for some reason EE programs the router to do this?
No, the ISP doesn't reduce the speed of your connection. It finds its own level.
  • For a BrightBox: login and go to Advanced Settings/ System/ DSL Status. Also post 'System Uptime' from top of System Log page.
  • For a SmartHub: login and go to Advanced Settings/ Technical Log/ Information. Obscure your names & any numbers in the BB Username & also the SSIDs.
Hi there
Sorry for the delay in getting back,  I had yet another visit from an Open Reach engineer - a three hour visit! He had other routers with him a Vodaphone one and an old BT one. They both had higher syn speeds than the EE ones (I have two, the original and a new one sent by EE).  The syn speed of Vodaphone was 15mb/s, BT 14mb/s and the EE ones 12mb/s. He doesn't know why EE is slower but suspects it is software.
I have the information you asked for, including a graph of the speed test result but the tables don't copy well and the graph not at all.  Perhaps you can suggest how these can be communicated.
With kind regards
David
Use the Camera icon above your text to upload an image file to here.
pip11
Scholarly Contributor
Just to add, the image will not appear until approved by a mod so don't think it hasn't worked.
