For up-to-date information and comments, search the EE Community or start a new topic.  |
22-07-2021 01:44 AM - edited 22-07-2021 01:45 AM
Hi did you ever find a solution to this issue,
I am on 2 EE routers and one I bought my self now and one openreach visit and my second coming on the 23rd,
router and first OR visit showed DL approx. Speed 32mbps and UL speed around the 5.5 mbps, the OR engineer felt the issue was at EE's end not receiving the data i am sending?
but when we do a speed test we see the DL speed fine but the UL speed is 0 and the internet is unusable,
so was there a solution found so i can pass this on to the EE agents I'm working with or the OR engineers so I can get this issue solved please?
22-07-2021 02:48 AM
@TimeyMaster : Welcome to EE's Home Broadband Forum.
22-07-2021 04:35 AM
1:-
2:- the test stops at testing the upload speed and will not go any further, here is a ookla one if that helps
3:-
22-07-2021 04:38 AM
just so you know the router was received today and installed around 2 hours ago
22-07-2021 04:57 AM
You are getting an upstream sync speed of 5 Meg, well within your expected range & towards the top of it. There's no reason for speedtests to report zero. Even on ADSL with an upstream speeds of about 1 Meg, speedtests would be capable of returning 0.9 Meg. You are running speedtests wired?
Your downstream speeds are fine.
22-07-2021 05:08 AM
yea this was preformed on a Ethernet connect pc but we get the same results on wifi, i also get a 0 mbps UL on my company BB speed checking, and thats why this is important to me as i work from home so i need this to be working
22-07-2021 05:21 AM
Could be faulty Ethernet. Try another cable. Try another router port.
22-07-2021 08:27 AM
Lol that won’t help the issue when it is happening on WiFi as well like I said in my last post!
22-07-2021 08:46 AM
@TimeyMaster are you able to test with a different device, and a different test site - ie speedtest.net
22-07-2021 09:03 AM - edited 22-07-2021 09:04 AM
It is the same on 1 pc on its own gigabyte Ethernet, 2 pcs on a 100 megabyte Ethernet, 1 laptop on WiFi, 2 phones on WiFi, 1 tablet on WiFi, tested with ookly speed test, bt wholesale speed test, my company’s speed test, Google’s speed test all showing 0 upload speed!
