04-08-2021 09:35 PM
We can’t even watch Netflix without it buffering constantly and the tv is hardwired Xbox doesn’t even get a look in.
why is it so bad?
04-08-2021 09:53 PM
You have not given much information to enable anyone to help you. So I have copied @XRaySpeX 's standard questions which if answered will give us more info to help you:
04-08-2021 10:32 PM
Hi @Justkev ,
In addition to the above very sensible suggestion, you may also want to take a quick note of the measured download bandwidth when visiting both of fast.com and speedtest.net
Netflix recommends that 25 Mbps is available but I've seen actual used bandwidth to be between 13 Mbps and 20 Mbps depending on the content. Netflix is usually quite good at reducing the content resolution to cope with low available bandwidth so I would imagine measured bandwidth would need to be sub 2 Mbps to really cause Netflix problems.
05-08-2021 07:34 AM
05-08-2021 08:27 AM
Until you post the requested info no-one will be ale to help you. "We" are not saying anything, you are.
05-08-2021 10:10 AM - edited 05-08-2021 10:15 AM
Hi @Justkev ,
Your device is not receiving data at a fast enough rate to give you a good experience.
This does not immediately mean it is any fault of the service provider. The community suggestions above are intended to arm you with the evidence and measurements so that you can discover whether there is any problem over which EE has control, and carrying out those steps should indicate the strategy to take to make things better (it may involve speaking to EE about those checks and the collected evidence, or it may not).
I would recommend that you carry out point 1. during a time when things are ok-ish and to check again when slow performance or pixilation occurs. Pixilation or corruption of the image suggests to me transmission error somewhere along the data path (again potentially no fault of the service provider) and the above recommendations from the community will help to pin point why those problems are seen (again arming you with evidence to help improve things). Usually a directly connected cable gives the best performance/stability (very small chance of a faulty cable, e.g. if you've put sharp bends in it during storage).
05-08-2021 10:28 AM
