23-05-2021 10:13 AM
Hi
can anyone tell me how to get these sites unblocked
116.205.4.114
on my data sim
also i cant turn of content filtering without going to an EE shop, as we don't use credit cards :rolleyes:
thanks
Stef
23-05-2021 10:48 AM - edited 23-05-2021 10:49 AM
Hi @sjpage10
Thanks for coming to the community 🙂
What happens when you try and view the web pages? Do you get an error message?
Is the data SIM pay as you go or a pay monthly contract?
Thanks 🙂
24-05-2021 08:03 AM
Thanks for the reply
its PAYG can't tell what happens as the data SIMS is in a GPS tracker
i know that i can send the APN config to it
APN: everywhere
Username: eesecure
Password: secure
and get a TXT message response saying its been configured
though no data is transferred via the device GPRS is not accessing the sites
i do now that these sites are blocked by some ISP's as i have had to use a VPN at times to access them
though any other sim in the tracker works fine once the APN has been set
stef
24-05-2021 09:17 AM
Would it make sense to put the PAYG SIM into a phone to test its functionality first, determine the correct settings, and then to place it back into the GPS tracker once everything is confirmed to work?
24-05-2021 09:17 AM
Hi @sjpage10.
Are you able to access these sites on another EE SIM card, maybe on a phone or tablet?
Have you used this device before on EE?
Jon
