close
Sim Card not working/being read?
PCanon
I have recently got the new Model:B625-261 router and it worked great and I had no issues, but starting my computer up today and it says "No SIM card is inserted into the device. Please insert a SIM card and restart the device, then try again." even though the router has not been opened/moved or even touched since the previous day when it was working.
I have removed the sim card and placed it back in and restarted the router multiple times before removing the sim card and afterwards to no success. I currently have no internet because of this and so need a solution as soon as possible.
Many Thanks
@PCanon  Try cleaning the sim with a damp cloth and make sure it’s dry before you put it back on the device.
This worked a treat!
Thanks very much!
