12-04-2021 07:33 PM - edited 12-04-2021 07:35 PM
Hello,
I am currently abroad and I am trying to send SMS using my PAYG plan. I tried multiple numbers but each time I get the message "unable to send message after multiple attempts". When I try to make a call I hear something like "this number are barred" (whichever number I use).
More details:
- The phone is connected to the network. I receive messages from EE
- I used some data on this plan while in UK
- I have active £1 Talk Pack
12-04-2021 10:12 PM
As you never used that PAYG SIM for making calls or texts in UK before you left to go abroad you can't now use it until you return to UK. EE PAYG SIMs need 1st activating on EE's home UK network.
12-04-2021 07:44 PM
Where are you a'roaming? If outside EU your pack is useless & you would need credit to pay for them.
12-04-2021 07:48 PM
Not EU. I have credit. How do I use it to send SMS? I thought I have to buy a pack like above.
12-04-2021 07:56 PM - edited 12-04-2021 07:57 PM
No, packs only valid in UK & EU.
As long as you have PAYG credit to cover it, you just send a text.
Again where are you?
12-04-2021 07:59 PM - edited 12-04-2021 08:08 PM
For some reason just using the credit does not work for me.
I'm in East Europe, non-EU country. I'd rather not say the exact location.
12-04-2021 09:21 PM
As it is not in EU, you cannot use your usual UK allowances there but will need to pay the charges as set out in e.g. https://ee.co.uk/help/help-new/roaming-costs/countries/moldova .
12-04-2021 09:41 PM
I understand this now (thanks to you). The question is why I can't send SMS or make a call when I have enough credit.
12-04-2021 09:44 PM
Does texting AL to 150 from it work & what does it fully report verbatim?
12-04-2021 09:53 PM
I already tried 150 several times. Immediate "unable to send message after multiple attempts".
I'm also reading "Text ROAMING to 150 before you go or enable international calls and texts from MyEE" on that roaming costs page. Does it actually apply to PAYG? I read elsewhere that roaming is enabled automatically on PAYG.
12-04-2021 09:57 PM
None of that applies to PAYG. PAYG is auto enabled for roaming. You won't see any of those settings & don't need to change anything.
Were you able to send texts when you were in UK?
