close
ESim passcode
RustyZane
Good morning everyone.
I just downloaded the esim from the eve app. I would like to put a unlock code on the esim when starting my phone.
soes anyone know the default code so that I can change it please.
have a great Sunday
Northerner
Hi @RustyZane
This is your default pin code under security you are looking for? If you changed this during the set up process then this will be different. Normal default codes are 1234 or 0000
Northerner
Hi @RustyZane
Hey. Thanks for the help. Greatly appreciated. Managed to get it sorted. Many thanks.
Sent from my iPhone X
RustyZane
Many thanks for your help. All sorted and appreciate the help. @Northerner
