29-03-2021 08:54 PM - edited 29-03-2021 08:59 PM
Has anyone else had issues with the battery life with the S21? I've had the phone less than a week and found myself needing to charge it twice a day when compared to the A70/A71 battery, which only needed to be charged once every 1-2 days
02-04-2021 09:30 AM
Have you noticed the battery life improve since you changed the adaptive brightness, @theguy3?
04-04-2021 09:23 AM - edited 04-04-2021 09:25 AM
Oh god, so you can't even return it.
It will likely be the pre-installed screen protector (that's plastic) that has gained the scratches, unless you took it off.
I don't know why that battery life seems so poor, take screenshots and post it here if possible - it does sound like either something is using massive amounts of battery or your phones battery is faulty (take it to a Samsung store)
04-04-2021 10:30 AM
galaxy s21 am i reading it right has a 4000 mAh
galaxy A70 4500mAh
galaxy A71 4500mAh
That is quite a bit of difference.
Try letting the battery go as flat as possible. Where the battery indicator usually goes orange let it go till the battery indicator goes red . then recharge fully.
This has previously given me more battery life..
04-04-2021 11:05 AM
The Samsung Galaxy S21 does have 4000mHa battery.
Two of their cheapo entry level phones the
A32 5g £229 has a 5000mHa battery
A42 5g £319 has a 5000mHa battery.
What are they playing at 4000mHa Not fit for purpose as you are finding out.
probably saves a billiometer of thickness on the sleek design.
04-04-2021 11:38 AM
@MrAngree Battery size matters yes but battery optimisation for the S21 should make it last longer.
The software helps you don't always need a big battery size
It is fit for purpose but the OP is obviously a heavy user.
04-04-2021 11:47 AM
Admittedly I am a heavy user but I was also a heavy user of the A70/A71 and the battery life for those phones were around 25% longer than the S21. So the S21 isn't fit for purpose if you're an extensive user of the phone, the A series is better suited for those who want to use their phone for longer than 5 hours a day.
04-04-2021 11:53 AM
i preferred the older phones with a removable battery , when you could just buy a couple
of extra battery's ... didn't matter so much about battery life them days.........i have
an old Samsung j3 with a removable battery .
04-04-2021 12:22 PM
@theguy3 wrote:Admittedly I am a heavy user but I was also a heavy user of the A70/A71 and the battery life for those phones were around 25% longer than the S21. So the S21 isn't fit for purpose if you're an extensive user of the phone, the A series is better suited for those who want to use their phone for longer than 5 hours a day.
You say that but you have been asked several times what does your battery usage state which apps are using up the battery to which you haven't responded.
There could a be rogue app.
Have you had a major update on it and if so have you preformed a factory restore?
04-04-2021 12:38 PM
I have previously stated that YouTube is the primary app that is used throughout the day, as it was for previous phones with it coming at over 50% of battery usage, second to that is Chrome. I've turned off adaptive brightness, turned off background location usage for all apps, tried switching to low power mode, waited for the battery to learn usage patterns, optimised the device several times and performed two factory resets.
04-04-2021 03:02 PM
the guy3
Just out of interest have you tried smartube its a real light weight version of you-tube.
i have it on my android tv boxes. this has no adverts and might take a bit less power from
your device.
https://apkpure.com/smart-tube/com.videoplayer.smarttube
you might have to side load it...
