close
Samsung Galaxy S21 Battery Life
theguy3
Has anyone else had issues with the battery life with the S21? I've had the phone less than a week and found myself needing to charge it twice a day when compared to the A70/A71 battery, which only needed to be charged once every 1-2 days
19 REPLIES 19
Northerner
Hi @theguy3
What does the battery usage app say?
At what % are you charging your phone? You might be charging it when you don't need to charge it. Even at lower % it has hours remaining.
To contact EE Customer Services dial 150 From your EE mobile or 0800 956 6000 from any other phone. You can call Freephone +44 800 079 8586 on Skype
Kirigaya_Kazuto
Star Contributor
Star Contributor
What apps are you using? have you got the screen on adaptive refresh rate?
It's started showing how long until the battery dies but originally said Learning Usage Patterns. I thought after this period had ended, the battery would return to normal but hasn't.
Normally I charge it at night and it's less than 20% and during the afternoon when it gets to around 15%.
I find when it gets to 7%, it says it has over an hour left but really lasts less than half an hour
Wow, you must be a very heavy phone user to nearly kill the phone twice over in a day. What are you using? tiktok, youtube, facebook?
Hi @theguy3
What is your usage pattern (what is a typical day usage?)
What does the battery app say?
I do use YouTube quite a bit during the day but I'm using it the same way as I did with the A70 and A71 and that never needed charging during the middle of the day. I was wondering if the battery for S21 was worse than the A70/A71 although I was under the impression that the S Series is supposed to be better
Typically I spend a lot of the day playing YouTube videos on and off in the background but I used to do this with the A70 and A71 and didn't have these issues. In fact I briefly had the A12 and used it the same way and despite that phone's shortcomings, the battery was never an issue. I also find just scrolling Twitter the morning with this phone, I lose about 5% in 15 mins
James_B
EE Community Manager
Hi @theguy3,
Have you tried reducing your screen brightness to see if that helps with your battery usage?
I have, turned off adaptive brightness and put it to a low setting. Tbh I'm starting to think the S21 is a joke of a phone with its awful battery life and my partner put it face down on a table and the screen as a couple of very noticeable scratches on it!
