19-11-2020 08:00 PM - edited 19-11-2020 08:08 PM
I got a Samsung A40 from Carphone Warehouse in January, on an EE contract. Over the past few months it keeps disconnecting the SIM card and saying 'No SIM card inserted'. It loses signal and the alert box often keeps popping up multiple times over a few minutes. This happens most days and sometimes several times in a day. When I took the SIM card out to have a look it looked like there were some scrapes along the surface of the SIM.
Wondering if there's a fault with the handset that's damaged the SIM? Any ideas on getting it fixed? Thanks.
19-11-2020 11:04 PM
Hi @KStimpson
Those marks are normal as the SIM needs to touch the SIM card. Have you dropped your phone or has it got wet in the past?
You can order a new SIM online as per EE guide. If you do this your original SIM will be deactivated once your replacement SIM us sent. Alternatively you can go into any EE store when they reopen, or call EE CS on 150.
19-11-2020 11:04 PM
Hi @KStimpson
21-11-2020 09:50 AM
Ah okay. Can't remember dropping it, definitely hasn't got wet.
I'll do that, thanks for your help
21-11-2020 10:06 AM
26-11-2020 07:58 PM - edited 26-11-2020 08:00 PM
New SIM card arrived but still not working. Recognises there is a SIM there and I haven't had the disconnected/no SIM message, however if I try to make a call it says 'not registered in network'. Generally says 'emergency calls only' but sometimes no message and full signal bars.
The information under simswap says to call 150 but I can't.
Any more ideas?
27-11-2020 07:41 AM - edited 27-11-2020 07:42 AM
Hi @KStimpson
Is your old SIM card still working?
Thanks 🙂
27-11-2020 06:27 PM
29-11-2020 06:42 PM
The original SIM is still intermittently disconnecting though
30-11-2020 07:57 AM
Hi @KStimpson
Thanks for coming back to me.
Have you registered the new SIM card?
Once the replacement SIM is registered you won't be able to use the old SIM this will show no service.
Thanks.
30-11-2020 07:01 PM
@Leanne_T I Iooked at that but if I click to say the SIM is to replace a damaged one it says it should be activated.
Other option for if it's for a new phone it looks like I need two working phones to have the SIM cards in?
It says to call 150 if I'm having problems but I've been having issues with the SIM disconnecting mid-call so not sure I'll be able to stay in a call long enough!
