07-12-2020 09:52 AM
EE showing order new sim but only two types.
My new phone looks like it needs a standard size so how do i know which one to choose.
Physical or ee sim?
when i ordered new sim, was told would be sent three, just in case but only received the smallest size sim.
thanks
07-12-2020 10:05 AM
Hi @janeanne
What phone are you upgrading from and to?
Upgrade phones are often supplied with a replacement pop-out SIM incase, for whatever reason, your existing SIM won't fit or work.
You should only need to pop out either the micro or nano part of that SIM if necessary.
07-12-2020 10:10 AM
Hi
my old phone is LG K4 2017
new phone is Alcatel u3 2019
do you know if stores have these in store as i need my phone for work?
07-12-2020 10:32 AM
It looks like the LG K4 2017 takes a micro-SIM, the Alcatel U3 a nano-size.
Was this a pay-monthly upgrade through EE? Or have you just bought the new phone yourself?
As I mentioned in my previous post, EE pay-monthly upgrades are often supplied with replacement SIMs on an "incase they're needed" basis. If that doesn't apply, and you're not able to just cut your existing one down to size, you can order a replacement one here
