on 29-03-2021 02:04 PM
Any body experience issues with android auto recently.
Worked fine with my Corsa up until a few months ago, possible update?
Does not work at all now.
I have uninstalled/ installed.
stopped short of doing a factory reset.
My S10 still works as well as my partners I phone 6E
thoughts n possible causes/solutions welcome
on 29-03-2021 02:23 PM
Hi @Emjayemc
It sounds like you're trying to connect your phone to your carkit via Bluetooth, is that correct?
What happens when you try to pair your phone to your carkit?
on 29-03-2021 02:26 PM
on 29-03-2021 02:39 PM
Blue tooth is working for calls.
when connected by usb lead Android Auto and all its features are displayed on in car screen.
Its just the S20 that refuses to play.
on 29-03-2021 10:08 PM
Hi @Emjayemc
Android auto changed to no longer be a specific app, rather it connects automatically. There are two options you can try. First is to go via the pairing process on the app on your phone, second is to ensure your care media software is fully updated.
You can also check comparability here:
