close
Router showing disconnected
alig3
I am using wifi and have logged into my router which is showing ‘disconnected ‘ can anyone explain this please….?
mikeliuk
Depending on the context in which that shows, most likely the device is temporarily disconnected from the cellular network.
Oftentimes this can be resolved with a simple reboot of the device following the online documentation.
Thanks but not sure what you mean by the online documentation…?
wardi
Star Contributor
Star Contributor
Do a coverage check with your postcode here, if your speed is well down or off you can report it if no one else has already done so.
https://coverage.ee.co.uk/coverage/ee
mikeliuk
Hi @alig3 ,
Some devices may have documentation here: https://deviceguides.ee.co.uk/
There's likely to be a reboot option in the interface. Pressing the power button is a good way to restart. If things completely lock up, you can pull the power (if possible).
In the coverage checking, hit "Check network".
