close
Return of old phone
deljeffery
I need to return a phone in Part ex but cant get hold of anyone to get a return pack. Can i return it at a store?
11 REPLIES 11
Christopher_B
EE Employee
Hi @deljeffery
When you do a trade in as part of your upgrade, we should send you a pack to send your phone.
When was it you did your upgrade?
I upgraded about a month ago.
Thanks @deljeffery
Since then have you had the chance to chase this up with our customer care team at all?
@deljeffery That's strange as we have no reports of any issues like this.
Can you remember what options you chose?
Profile closed
Not applicable
@deljeffery call freephone 0800 956 6000 select option 2 then option 4 and you will get through to a customer service advisor 🙂
Sent from my iPhone
HI,
I selected 2 then tried to select 4 but there is no option 4.
Profile closed
Not applicable
@deljeffery ring freephone 0800 317 720 there's no options that way it will put you straight through to someone.
