close
Replacement sim is the wrong size
Peter441
I ordered a replacement sim as I've just purchased a new iPhone SE. I've been sent a micro sim but need a Nano sim. I'm on PAYG. I can't get through to get the correct sim sent to me. Can someone help?
Many thanks,
Peter
Hi @Peter441
You should just be able to cut the SIM down to whatever size you need - there should be slight perforation marks on the plastic surface that you carefully cut along with a suitable knife.
Thank you! Just realised!
Thanks for your response
