close
Registering device to number
Rossi08
Hi I am desperately trying to register a number to connect to a devicebut website doesn't alliw this   Helppppp I need to connect asap.  Thank you
MyEE doesn't work for registering PAYG MBB devices. It stops at telling you to connect your device & login to it, but when you've done as instructed it doesn't have anywhere for you to say you've done it.
You may continue using your MBB but you just can't register it to MyEE.
Go to http://add-on.ee.co.uk/status from a device connected to the router will tell you your usage.
Go to http://add-on.ee.co.uk/purchase from a device connected to the router to buy add-ons.
So how does the number connect to the device?
The no. is on the SIM & the SIM connects to the EE mobile network. You don't need to register it to MyEE to use it.
